Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing in Unattended and Console Modes > Installing and Configuring in Console Mode >
Editing siebel.ini Files for Console Mode Installation
Before starting the installation, you must disable portions of the siebel.ini file.
After you finish the installation, launch the configuration in console mode from the configuration subdirectory (such as Siebel_Enterprise_Server/gtwysrvrcfg) and launch the installation and server configuration wizards separately.
To modify siebel.ini files for console mode installation
  1. Using a text editor, modify the appropriate siebel.ini file or files as listed below:
    NOTE:  Make a copy of each siebel.ini file you plan to modify, and save it in a unique location that identifies the module it pertains to. Preserve these copies in case you may need them for later reference.
    • Siebel Enterprise Server. UNIX_OS/Server/Siebel_Enterprise_Server/siebel.ini.
    • Siebel Web Server Extension. UNIX_OS/Server/Siebel_Web_Server_Extension/siebel.ini.
      CAUTION:  When you modify a siebel.ini file, make sure that you enter the correct values, because your entries are not validated by the installer.
  2. Locate the [RunAfter.Unix] section and change the values for the following parameters:
    ConfigGtwysrvr = no
    ConfigSiebsrvr = no
    Config.SWSE.Unix = no
