Siebel System Administration Guide > Administering Siebel Server Run-Time Operations > Administering Component Jobs >
Holding a Component or Repeating Component Job
This topic describes the procedure for holding component jobs. You can only hold component jobs that have a state of Queued.
Holding a component job pauses the applicable task (if the task is pausable) or allows the current task to finish. No new tasks begin for the held component job.
To hold a component or repeating component job
  1. From the application-level menu, choose Navigation > Site Map > Administration - Server Management.
  2. From the link bar, click Jobs.
  3. In the Jobs list, select the component job that has a Status field value of Queued.
    NOTE:  You cannot hold jobs with an Active value in the Status field.
  4. Click the Hold button.
