Siebel System Administration Guide > Administering Siebel Server Run-Time Operations > Administering Siebel Servers > Starting Up a Siebel ServerThis topic describes the procedure for starting up a Siebel Server. For background information on Siebel Server states, see System Monitoring and Diagnostics Guide for Siebel Business Applications. For information on other Siebel Server management tasks, see Administering Siebel Servers. NOTE: In order to start the Siebel Server, the Siebel Server System Service must be running. For more information, see Administering the Siebel Server System Service. If the Auto Startup Mode (alias AutoStart) Siebel Server parameter is set to the default value of TRUE, the Siebel Server starts automatically when the Siebel Server System Service is started. NOTE: Starting a Siebel Server starts the default number of tasks (as defined in the Default Tasks [alias DfltTasks] parameter) for each background-mode component. |
Siebel System Administration Guide |
