Siebel System Administration Guide > Administering Siebel Server Run-Time Operations > Administering Siebel Server Tasks >
Configuring Siebel Server Task Dynamic Parameters
This topic describes the procedure to configure dynamic parameters of a Siebel Server task. Siebel Server task parameters consist of Siebel Enterprise Server, Siebel Server, and server component-level parameters, as well as task-specific parameters specified when starting a component job. After a task is running, only dynamic parameters may be changed.
For background information on system parameters, see About Siebel System Parameters. For background information on Siebel Server task parameters, see About Task Parameters.
For further information on administering Siebel Server tasks, see Administering Siebel Server Tasks.
To configure Siebel Server task dynamic parameters
  1. Navigate to the Administrations - Server Management screen.
  2. From the link bar, click Tasks.
  3. In the Tasks list, select the running Siebel Server task of interest.
  4. Click the Parameters tab.
  5. In the Task Parameters list, change the values of the parameters you want to modify. (Identify dynamic parameters by a check in the Effective Immediately column.)
    1. Select the parameter that you want to modify.
    2. In the Value field, type in the new value.
    3. Click the menu button and then Save Record.
For a list of component parameters and their related attributes, see Parameters.
