Siebel System Administration Guide > Configuring the Browser for Siebel Web Clients > High-Interactivity Deployment—ActiveX Requirements >
ActiveX Controls Distributed for High Interactivity
Table 13 lists the ActiveX controls distributed and used with Siebel Web clients. All of these controls are signed. Control names reflect the names of the files that are created in the Downloaded Program Files directory when each control is deployed.
NOTE:  Depending on your Siebel software release, you may have only a subset of these CAB files.
Table 13. ActiveX Controls Used with Siebel Web Clients
Filename / Control Name
Feature / Function
Siebel Calendar
Supports calendar-related functions.
Siebel Generic Container Control
Hosts third-party ActiveX controls. The hosted control, its methods, and its public members are specified using control user properties.
In Siebel Life Sciences, this control hosts the CIC Ink control, used for capturing signatures on a tablet PC.
Siebel Callcenter Communications Toolbar
Helps the communications (CTI) toolbar Java applet to access the client framework.
See also Siebel Communications Server Administration Guide.
Siebel Desktop Integration
COM interface to support client-side integrations your company may implement.
When this control is deployed, the EnableWebClientAutomation parameter must be TRUE in the application configuration file.
NOTE:  Running this control requires the user to have the permissions associated with the Power Users group.
Siebel ERM eBriefings offline content Synchronization
Supports synchronization of offline content for Siebel ERM and eBriefings.
NOTE:  Running this control requires the user to have permissions associated with the Power Users group.
Siebel Gantt Chart
Supports Gantt Charts in the Siebel application UI.
Gantt Chart control renders data in two panes: the left pane for owner objects (employees, projects, campaigns, and so on), and the right pane for the owner objects' schedules and activities.
Siebel Hospitality Gantt Chart
Supports Gantt Charts for Siebel Hospitality.
Siebel High Interactivity Framework
Provides high levels of usability, performance, and desktop integration. Contains user interface components such as a rich text editor, UI elements, and so on. The browser health check is also provided through this control.
NOTE:  Deploying this control is required for all high-interactivity applications.
Siebel iHelp
Supports the Siebel iHelp player panel to contain and display iHelp information.
Siebel Marketing Allocation
Works with Siebel Analytics to display market segment information applicable to a stage in a marketing program.
Siebel Marketing Event Calendar
Supports the Siebel Marketing Event Calendar.
Siebel Marketing Web Editor
Supports editing of email offers, Web offers, and event Web banner for Siebel Marketing applications.
Siebel Microsite Layout Designer
Provides a tool for laying out page items in ERM microsites and templates.
Siebel Outbound Email Support
Supports client-side email integration (for Lotus Notes or Microsoft Outlook).
NOTE:  Deploying this control requires that you also deploy the Siebel Desktop Integration control.
Provides a hidden control to render the standard interactivity applets for high-interactivity product selection UI views. The control inserts standard-interactivity HTML into a placeholder span.
Siebel SmartScript
Provides the SmartScript UI.
See also Siebel SmartScript Administration Guide.
Siebel Test Automation
Provides a test automation interface. (Generally not used for production environments.)
See also Testing Siebel Business Applications.
Siebel Universal Inbox
Supports the Universal Inbox feature.
A third-party ActiveX control used to capture and encrypt signatures.
A third-party ActiveX control provided by Microsoft for use with the Exchange/Siebel Connector (PIMSE). It is required only for implementations with Outlook 2000.
