Siebel System Administration Guide > Configuring Siebel Servers > Configuring the Siebel Server >
Disabling Components on a Siebel Server
This topic describes disabling Siebel Server components on a Siebel Server. For background information on enabling and disabling server components, see About Enabling and Disabling Siebel Server Components.
For information on other Siebel Server configurations, see Configuring the Siebel Server.
To disable a component on a Siebel Server
  1. From the application-level menu, choose Navigation > Site Map > Administration - Server Configuration.
  2. From the link bar, click Servers.
  3. In the Siebel Servers list, select the Siebel Server of interest.
  4. In the Components list, select the server component you want to disable.
  5. Click the Disable button.
    The Enable State field of the component record changes to Disabled.
