Siebel System Administration Guide > Configuring Siebel Servers >
Process for Creating a Custom Siebel Server Component
This topic describes the process to create a custom Siebel Server component.
Perform the following tasks to create a custom Siebel Server component:
  1. Create a new component group. See Creating a Custom Siebel Server Component Group for information on this task. This task is optional if you plan to add the new custom Siebel Server component to an existing component group.
  2. Create a new component definition. See Creating a Custom Siebel Server Component Definition for information on this task.
  3. Enable the new component definition. See Enabling a Siebel Server Component Definition for information on this task.
  4. Synchronize components if the new custom Siebel Server component is a batch-mode component. See Synchronizing Components on a Siebel Enterprise Server for information on this task.
  5. Stop and restart the Siebel Server System Service. See Administering the Siebel Server System Service for information on this task.
