Siebel System Administration Guide > Configuring Siebel Servers > About Siebel System Parameters > About Advanced ParametersParameters that affect or modify advanced product functionality are, by default, hidden from the Server Manager GUI. To make advanced parameters visible on a particular Siebel Server, set the component-level parameter Show Advanced Objects (alias ShowAdvancedObjects) to TRUE for the server component Server Manager (alias ServerMgr). The default value for this parameter is FALSE. For information on setting component parameters, see Configuring Siebel Server Component Parameters. For information on listing advanced parameters in the command-line interface, see List Commands. |
Siebel System Administration Guide |
