Siebel System Administration Guide > Configuring the System Architecture >
Backing Up the Siebel Gateway Name Server Data
It is recommended that you make a backup of the Siebel Gateway Name Server data—which contains configuration information from the Enterprise and Siebel Servers—prior to and after making any configuration changes, especially creating new component definitions and adding or deleting Siebel Servers. The Siebel Gateway Name Server information is stored in the siebns.dat file located in the Administration folder of the Siebel Gateway Name Server root directory. The backup procedure flushes out the latest changes from memory into the siebns.dat file and makes a backup copy. See Backing Up a Siebel Enterprise Server for information on making a backup of the siebns.dat file using the Server Manager GUI. See To back up Siebel Gateway Name Server information for information on making a backup of the siebns.dat file using the Server Manager command-line interface.
If the Siebel Server does not start up due to recent configurations or a corruption of the current siebns.dat file, use the following procedure with a working backup siebns.dat file. (The siebns.dat file can become corrupt for many reasons, such as inconsistent data or write errors.)
