Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands > Command SyntaxThis chapter lists the command-line syntax and usage for Siebel Server Manager commands. Component names and parameter names used in the command-line interface differ from the Siebel Server Manager GUI. To get the actual component and parameter names used in the command-line interface use the list commands. For information on using list commands, see List Commands. For user-defined values such as For example, you need to enclose the Siebel Server name in double quotes for the following command because the Siebel Server name contains a space: start task for component EIM server "North America" with Config=default.ifb NOTE: If a srvrmgr command happens to contain nested quotes, that is, quotes contained within quotes, precede the inner quotes by the back slash escape character (\). |
Siebel System Administration Guide |
