Siebel System Administration Guide > Using the Siebel Server Manager Command-Line Interface > Siebel Server Manager Commands >
Siebel Server Manager Environment Commands
Use environment commands to set the Siebel Server Manager environment variables, which control the current Siebel Server Manager session.
To set the current working Siebel Server
  • Enter:
    set server siebel_server_name
    This command works only if you did not specify a Siebel Server when executing the srvrmgr program by using the -s flag.
To unset (clear) the current working Siebel Server
  • Enter:
    unset server
To show the environment variables
  • Enter:
    show
To show an individual environment variable
  • Enter:
    show variable_name
To spool output to a file
  • Enter:
    spool output_file
To stop spooling to a file
  • Enter:
    spool off
To read commands from a file
  • Enter:
    read input_file
To refresh the Siebel Enterprise Server connections
  • Enter:
    refresh enterprise
    The refresh Siebel Enterprise Server command closes all connections to the existing Siebel Servers and creates new connections to these servers.
To remove header and footer information from srvrmgr command-line output
  • Enter:
    set header false
    and
    set footer false
Removing the header and footer information is useful if you are trying to parse the output of srvrmgr commands.
To add header and footer information to the srvrmgr command-line output
  • Enter:
    set header true
    and
    set footer true
To exit the Srvrmgr program
  • Enter:
    exit
    or
    quit
To save any configuration changes prior to exiting, see To back up Siebel Gateway Name Server information.
