Siebel System Administration Guide > Administering Server System Services > Administering the Siebel Server System Service >
Siebel Server System Service on Windows
This section describes how to start, stop, and check the Siebel Server System Service on Windows. To start the Siebel Server System Service on Windows
- Right-click on My Computer.
- Click Manage.
The Computer Management panel appears.
- In the Tree applet, double-click Services and Applications.
- Click Services.
- In the right applet, scroll through the list of services and select the desired Siebel Server service (the enterprise name and Siebel Server name are indicated within square brackets).
- Right-click the desired Siebel Server service and select Start.
Windows starts the Siebel Server System Service. This may take a few seconds. After the service has started, the Status field changes to Started.
To stop the Siebel Server System Service on Windows
- Click Manage.
- Click Services.
- Right-click the desired Siebel Server service and select Stop.
Windows stops the Siebel Server System Service. This may take a few seconds. After the service has stopped, the Status field is blank.
NOTE: A Microsoft Windows 1053 error may occur during this process. This error does not affect the Siebel Server System Service from stopping.
To check the status of the Siebel Server System Service on Windows
- Click Manage.
- Click Services.
A value of Started in the Status field for the selected service indicates that the System Service is running for the Siebel Server. If the Status field is blank, the System Service is not currently running.
