Siebel Territory Management Guide > Getting Started with Territory Management >
About Getting Started with Territory Management
This chapter lists the applications administration tasks that are specific to Territory Management. Use this chapter in combination with the Applications Administration Guide and the Security Guide for Siebel Business Applications.
The Applications Administration Guide and the Security Guide for Siebel Business Applications cover the setup tasks that are common to all Siebel Business Applications, such as using license keys, defining employees, and defining your company's structure. The Applications Administration Guide also provides the information that you need to perform data administration and document administration tasks.
This guide assumes that you have already installed or completed the upgrade of your Siebel application. If you have not, go to the Installation/Upgrade section of the Siebel Bookshelf and click the links to the guides that are relevant to your company's implementation.
The Siebel Installation Guide for the operating system you are using describes how to create the Siebel Administrator account that is used to perform the tasks described in this guide.
