Siebel Territory Management Guide > Getting Started with Territory Management >
Configuring End-Date Behavior for Territory Nodes
In the preconfigured application, territory node records become read-only when a record's effective end date has passed.
Depending on your business requirements, you may want to reconfigure this behavior so that territory node records do not become read-only after the effective end date.
To allow territory nodes to be edited after the effective end date
  • In Siebel Tools, for the Territory Hierarchy Node business component, inactivate the user property called BC Read Only Field.
