Testing Siebel Business Applications > Design and Develop Tests > Test Case Authoring >
System Test Cases
System test cases are typically used in the system integration test phase to make sure that a component or module is built to specification. Where functional tests focus on validating support for a scenario, system tests make sure that the structure of the application is correct. Table 3 shows some examples of typical system tests.
Table 3. Common System Test Cases
Object Type
Example
Interface
Verify that an interface data structure has the correct data elements and correct data types.
Business Rule
Verify that a business rule (for example, assignment rule) handles all inputs and outputs correctly.
