Testing Siebel Business Applications > Design and Develop Tests >
Test Case Automation
Siebel Systems partners with the leading test automation tool vendors, who provide validated integrations to Siebel 7. Automation tools can be a very effective way to execute tests. In the case of performance testing, automation tools are critical to provide controlled, accurate test execution. When you have defined test cases, you can automate them using third-party tools.
