Testing Siebel Business Applications > Functional Test Object Reference >
SiebPageTabs Object
The SiebPageTabs object provides methods and properties that allow you to navigate page tabs in a test automation environment.
Parent
The SiebPageTabs object is a child of the SiebApplication Object.
Type
The SiebPageTabs object is a singleton collection object that is one of the Navigation Objects.
Events
The SiebPageTabs object has the following events.
Event Name
Description
GotoScreen (ScreenName)
Navigates to a PageTab. ScreenName is a String that specifies the RepositoryName of the PageTab object.
GotoView (ViewName)
Navigates to a View. ViewName is a String that specifies the RepositoryName of the View object, represented by an Aggregate Category link.
Methods
The following methods are available from the SiebPageTabs object:
For a description of these methods, see SiebPageTabs Methods.
Properties
The SiebPageTabs object has the following properties.
Property Name
Type
Description
ActiveScreen
String
Indicates the RepositoryName of the active PageTab object.
ActiveView
String
Indicates the RepositoryName of the active View, as represented by the active Aggregate Category link.
ClassName = "SiebPageTabs"
Const String
See Common Test Automation Object Properties for a description of this property.
RepositoryName = "SiebPageTabs"
Const String
ScreenCount
Integer
The total count of PageTabs for Screen navigation.
UIName = "PageTabs"
Const String
ViewCount
Integer
The total count of available (using Aggregate Category links) from the active PageTab object.
