Testing Siebel Business Applications > Overview of Testing Siebel Applications > Overview of the Siebel Testing Process > Improve and Continue TestingTesting is not complete when the application is rolled out. After the initial deployment, regular configuration changes are delivered in new releases. In addition, Siebel Systems delivers regular maintenance and major software releases that may need to be applied. Both configuration changes and new software releases require regression testing to verify that the quality of the system is sustained. The testing process should be evaluated after deployment to identify opportunities for improvement. The testing strategy and its objectives should be reviewed to identify any inadequacies in planning. Test plans and test cases should be reviewed to determine their effectiveness. Test cases should be updated to include testing scenarios that were discovered during testing and were not previously identified, to reflect all change requests, and to support software releases. |
Testing Siebel Business Applications |
