Upgrade Guide > Upgrading the Siebel Database > Preparing for a No-Development-Environment Siebel UpgradeUpgrades: All Siebel upgrades. Environments: Production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. If your installation does not include a development environment, you do not need to merge your Siebel Repository. Instead, you can use the repository and schema definition files included in the Siebel Database Server installation. Before performing the upgrade, you must move and rename these files. To prepare for a no-development-environment upgrade
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
