Upgrade Guide > Upgrading the Siebel Database >
Running the Siebel Database Server Configuration Utilities Under Windows
Upgrades: All Siebel upgrades.
Environments: Development, production test, production.
Platforms: Windows only.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
Run the Database Server Configuration Utilities to upgrade the Siebel Database. The Utility collects information, populates a master configuration file, and calls the SQL generator to create SQL commands. The Upgrade Wizard then uses the configuration file and SQL commands to upgrade the Siebel Database.
For more information on the Database Server Configuration Utilities, see About the Siebel Database Server Configuration Utilities.
Prerequisite: Collect the information that the Database Server Configuration Utilities requires. See Preparing to Run the Siebel Database Server Configuration Utilities.
To run the Database Server Configuration Utilities under Windows
  1. Verify that no server tasks are running in the background.
    If necessary, stop Siebel Servers and Siebel Gateway Name Server service by navigating to Start > Settings > Control Panel > Services.
  2. Select Start > Programs > Siebel Enterprise Servers 7.x > Configure DB Server.
    The first window of the Database Server Configuration Utilities appears.
  3. Enter the information requested in each window and click Next.
    To return to previous windows, click Previous.
  4. When the "runnow" window displays, do the following:
    • Upgrep mode: Answer No. Do not start the Upgrade Wizard.
    • Upgphys mode: Answer Yes to start the Upgrade Wizard.
    • Prepare for Production mode: Answer Yes to start the Upgrade Wizard.
      Just before displaying the runnow window, the Database Server Configuration Utilities calls the SQL generator to create or populate SQL scripts.
      To manually start the Upgrade Wizard, see Starting the Siebel Upgrade Wizard.
Upgrade Guide Copyright © 2006, Oracle. All rights reserved.
