Upgrade Guide > Siebel Postmerge Development Tasks > Updating Siebel Enterprise Application Integration (EAI)Upgrades: All Siebel upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. If you use Enterprise Application Integration (EAI), perform the following procedure to update the definitions of the Business Objects to account for changes in data type, length, edit format or other properties. To upgrade integration objects
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
