Upgrade Guide > Reviewing the Siebel User Interface > Eliminating Obsolete Siebel UI FieldsUpgrades: All Siebel upgrades. This topic applies only to upgrades using the Incorporate Custom Layout (ICL) feature. Environments: Development environment only. Reputility log section: "Issue 7: Fields deprecated from Business Components." This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Some of the business component fields in your installed release may be obsolete in the new release. If you have customized existing applets or created new ones, and you selected ICL during the merge, the UI may contain obsolete fields or controls. If a business component field is not available for an applet field or control after the merge, the field or control does not display. The reputility log lists the applets that contain obsolete business component fields. Review the section of the log referenced above and revise applet definitions and layouts as required.
SIEBEL_TOOLS_INSTALL_DIR is the directory where Siebel Tools is installed. |
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
