Upgrade Guide > Basic Database Preparations for a Siebel Upgrade >
Verifying Siebel Database Connectivity
Upgrades: All Siebel upgrades.
Environments: Development, production test, production.
Databases: All databases.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
From the production test environment, you must be able to make ODBC connections to both the Siebel Database in the development environment and the Siebel Database in the production environment. Verify that you can define these ODBC connections in the production test environment.
If you cannot connect to these databases from the production test environment, contact Oracle's Siebel Technical Support.
In the production environment, you do not have to define an ODBC connection to the development environment Siebel Database or the production test environment Siebel Database.
Upgrade Guide Copyright © 2006, Oracle. All rights reserved.
