Upgrade Guide > Basic Database Preparations for a Siebel Upgrade > Preserving Siebel Dock Objects and Visibility RulesUpgrades: All Siebel upgrades. Environments: Development, production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Modified visibility rules are dropped during a development environment upgrade. Manually record any changes to dock object visibility rules, so you can evaluate whether you must reapply the changes after the upgrade is complete. Dock objects and visibility rules created by using Docking Wizard are preserved unless they become invalid after the upgrade. Manually record any changes that you made through the Docking Wizard so that you can evaluate whether you need to reapply the changes after the upgrade is complete. Changing the definition of dock objects requires the assistance of Oracle's Siebel Technical Support or Oracle's Siebel Expert Services. |
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
