Upgrade Guide > Preparing an IBM DB2 Database for a Siebel Upgrade > Verifying IBM DB2 Sort Order for a Siebel UpgradeUpgrades: All Siebel upgrades. Environments: Development, production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Binary sort order is required for the development environment upgrade and is strongly recommended for the production environment upgrades. Sort order is specified during creation of the database. If you find that your IBM DB2 development database was not created using Identity sort order, you must re-create your database using the option If sort order is correct, but you are still encountering errors, contact Oracle's Siebel Technical Services for further analysis. Related TopicAbout Database Sort Order in the Siebel Environment To verify that your database was created using Identity sort order |
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
