Upgrade Guide > Preparing an Oracle Database for a Siebel Upgrade >
Verifying Oracle Database Configuration for a Siebel Upgrade
Upgrades: All Siebel upgrades. Environments: Development, production test, production. Databases: Oracle only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. This topic provides upgrade-specific settings for the Oracle RDBMS. Use the following strategy to set parameters:
- Set parameters using the recommendations in Siebel Installation Guide for the operating system you are using. Recommendations are located in the chapter on configuring the RDBMS.
- For the upgrade, revise the configuration parameters listed below.
- After the upgrade, reset the configuration parameters to the values listed in Siebel Installation Guide for the operating system you are using.
Before upgrading an Oracle database, complete the following tasks:
- Read System Requirements and Supported Platforms on Siebel SupportWeb to determine the supported Oracle version and any required patches. If required, upgrade your Oracle database and client software to the supported version, using Oracle's tools and documented procedures.
- Verify that your Oracle clients and Oracle database server are at the same release level.
- UNIX only. If you have installed the Oracle 64-bit client on the Siebel Server, verify that $ORACLE_HOME/lib32 instead of $ORACLE_HOME/lib is included in LIBPATH (AIX), SHLB_PATH (HP-UX), LD_LIBRARY_PATH (Solaris).
- pctincrease. For upgrades, compute a high enough value for
pctincrease on tablespaces that contain application tables and indexes so that upgrading does not create large numbers of extents.
- pctfree. Rebuild some of your larger tables with a large value for
pctfree (30 or higher). Table size depends on which Siebel applications you have installed. For example, if you are upgrading Siebel Financial Services, S_ASSET is a large table and S_ADDR_ORG is not used at all.
You must increase pctfree before the upgrade because many new columns are added to tables during the upgrade. Migrating data into the new columns during the upgrade is likely to cause row chaining, which degrades upgrade performance.
- DB_CACHE_SIZE. Set this parameter to a minimum of 394264576.
- SORT_AREA_SIZE. Set this parameter to a minimum of 1524288. This significantly reduces the time required to complete a repository merge.
- Other init.ora parameters that the DBA should review are:
- sort_area_retained size
- log_buffers
- UNDO_MANAGEMENT (Oracle 9i and later). Set UNDO_MANAGEMENT = MANUAL before the repository merge. This turns off Automatic Undo Management (AUM). You can turn AUM back on after the repository merge, as desired. For more information on how AUM affects upgrade, see Alert 848 on Oracle's Siebel SupportWeb.
- Rollback Segments. Verify that you have only one large rollback segment on line that is appropriately sized so that the largest of transactions can be accommodated. Take all other rollback segments off line.
The upgrade may affect some of the largest tables in your implementation of Siebel 7.x, causing them to grow by as much as 40%.
Customer experience has shown that repository merges involving multiple languages can require a rollback segment as large as 1 GB.
