Upgrade Guide for DB2 UDB for z/OS > Columns Denormalized During Upgrade to Release 7.8 >
Denormalized Columns for 6.2.1 Siebel Financial Services Applications
Table 49 lists columns that are denormalized during upgrades from Release 6.2.1 Siebel Financial Services applications to Release 7.8 Siebel Industry applications.
Table 49. Columns Denormalized During Upgrades from Release 6.2.1 Siebel Financial Services Applications
Target Table
Target Column
Denorm Path
Source Table
Source Column
S_ACCNT_POSTN
ACCNT_TYPE_CD
[OU_EXT_ID].[ACCNT_TYPE_CD]
S_ORG_EXT
ACCNT_TYPE_CD
S_ACT_CAL_RSRC
ACT_APPT_REPT_FLG
[ACTIVITY_ID].[APPT_REPT_FLG]
S_EVT_ACT
APPT_REPT_FLG
S_ACT_CAL_RSRC
ACT_APPT_RPTEND_DT
[ACTIVITY_ID].[APPT_REPT_END_DT]
S_EVT_ACT
APPT_REPT_END_DT
S_ACT_CAL_RSRC
ACT_CAL_TYPE_CD
[ACTIVITY_ID].[CAL_TYPE_CD]
S_EVT_ACT
CAL_TYPE_CD
S_ACT_CAL_RSRC
ACT_TEMPLATE_FLG
[ACTIVITY_ID].[TEMPLATE_FLG]
S_EVT_ACT
TEMPLATE_FLG
S_ACT_CAL_RSRC
ACT_TODO_PLNEND_DT
[ACTIVITY_ID].[TODO_PLAN_END_DT]
S_EVT_ACT
TODO_PLAN_END_DT
S_ACT_CAL_RSRC
ACT_TODO_PLNSTRTDT
[ACTIVITY_ID].[TODO_PLAN_START_DT]
S_EVT_ACT
TODO_PLAN_START_DT
S_ACT_EMP
ACT_ALARM_FLG
[ACTIVITY_ID].[ALARM_FLAG]
S_EVT_ACT
ALARM_FLAG
S_ACT_EMP
ACT_APPT_REPT_FLG
S_EVT_ACT
APPT_REPT_FLG
S_ACT_EMP
ACT_APPT_RPTEND_DT
S_EVT_ACT
APPT_REPT_END_DT
S_ACT_EMP
ACT_APPT_START_DT
[ACTIVITY_ID].[APPT_START_DT]
S_EVT_ACT
APPT_START_DT
S_ACT_EMP
ACT_CAL_DISP_FLG
[ACTIVITY_ID].[CAL_DISP_FLG]
S_EVT_ACT
CAL_DISP_FLG
S_ACT_EMP
ACT_CAL_TYPE_CD
S_EVT_ACT
CAL_TYPE_CD
S_ACT_EMP
ACT_EVT_STAT_CD
[ACTIVITY_ID].[EVT_STAT_CD]
S_EVT_ACT
EVT_STAT_CD
S_ACT_EMP
ACT_TEMPLATE_FLG
S_EVT_ACT
TEMPLATE_FLG
S_ACT_EMP
ACT_TODO_PLNEND_DT
S_EVT_ACT
TODO_PLAN_END_DT
S_ACT_EMP
ACT_TODO_PLNSTRTDT
S_EVT_ACT
TODO_PLAN_START_DT
S_AGREE_POSTN
AGREE_NAME
[AGREE_ID].[NAME]
S_DOC_AGREE
NAME
S_AGREE_POSTN
AGREE_STAT_CD
[AGREE_ID].[STAT_CD]
S_DOC_AGREE
STAT_CD
S_AGREE_POSTN
AGREE_VALID_FLG
[AGREE_ID].[VALID_FLG]
S_DOC_AGREE
VALID_FLG
S_ASSET_BU
ASSET_NUM
[ASSET_ID].[ASSET_NUM]
S_ASSET
ASSET_NUM
S_ASSET_BU
TYPE_CD
[ASSET_ID].[TYPE_CD]
S_ASSET
TYPE_CD
S_CASE_BU
CASE_NAME
[CASE_ID].[NAME]
S_CASE
NAME
S_CASE_BU
CASE_STATUS_CD
[CASE_ID].[STATUS_CD]
S_CASE
STATUS_CD
S_CASE_BU
CASE_TYPE_CD
[CASE_ID].[TYPE_CD]
S_CASE
TYPE_CD
S_CONTACT_BU
AGENT_FLG
[CONTACT_ID].[AGENT_FLG]
S_CONTACT
AGENT_FLG
S_CONTACT_BU
CON_EMP_FLG
[CONTACT_ID].[EMP_FLG]
S_CONTACT
EMP_FLG
S_CONTACT_BU
CON_FST_NAME
[CONTACT_ID].[FST_NAME]
S_CONTACT
FST_NAME
S_CONTACT_BU
CON_LAST_NAME
[CONTACT_ID].[LAST_NAME]
S_CONTACT
LAST_NAME
S_CONTACT_BU
CON_MID_NAME
[CONTACT_ID].[MID_NAME]
S_CONTACT
MID_NAME
S_CONTACT_BU
MEMBER_FLG
[CONTACT_ID].[MEMBER_FLG]
S_CONTACT
MEMBER_FLG
S_CONTACT_BU
PROVIDER_FLG
[CONTACT_ID].[PROVIDER_FLG]
S_CONTACT
PROVIDER_FLG
S_CTLG_CAT_AUC
AUC_AUC_LOT_NUM
[AUC_ITEM_ID].[AUC_LOT_NUM]
S_AUC_ITEM
AUC_LOT_NUM
S_CTLG_CAT_CRSE
CRSE_NAME
[CRSE_ID].[NAME]
S_CRSE
NAME
S_CTLG_CAT_CRSE
CRSE_SUB_TYPE
[CRSE_ID].[SUB_TYPE]
S_CRSE
SUB_TYPE
S_CTLG_CAT_DFCT
DFCT_DFCT_NUM
[PROD_DEFECT_ID].[DEFECT_NUM]
S_PROD_DEFECT
DEFECT_NUM
S_CTLG_CAT_ISS
ISS_NAME
[ISS_ID].[NAME]
S_ISS
NAME
S_CTLG_CAT_LIT
LIT_NAME
[LIT_ID].[NAME]
S_LIT
NAME
S_CTLG_CAT_ORG
ORG_CMPT_FLG
[ORG_ID].[CMPT_FLG]
S_ORG_EXT
CMPT_FLG
S_CTLG_CAT_ORG
ORG_LOC
[ORG_ID].[LOC]
S_ORG_EXT
LOC
S_CTLG_CAT_ORG
ORG_NAME
[ORG_ID].[NAME]
S_ORG_EXT
NAME
S_CTLG_CAT_ORG
ORG_PRTNR_FLG
[ORG_ID].[PRTNR_FLG]
S_ORG_EXT
PRTNR_FLG
S_CTLG_CAT_PROD
PROD_EFF_END_DT
[PROD_ID].[EFF_END_DT]
S_PROD_INT
EFF_END_DT
S_CTLG_CAT_PROD
PROD_EFF_START_DT
[PROD_ID].[EFF_START_DT]
S_PROD_INT
EFF_START_DT
S_CTLG_CAT_PROD
PROD_NAME
[PROD_ID].[NAME]
S_PROD_INT
NAME
S_CTLG_CAT_SR
SR_SR_NUM
[SRV_REQ_ID].[SR_NUM]
S_SRV_REQ
SR_NUM
S_CTLG_CAT_SRC
SRC_NAME
[SRC_ID].[NAME]
S_SRC
NAME
S_CTLG_CAT_SRC
SRC_SRC_NUM
[SRC_ID].[SRC_NUM]
S_SRC
SRC_NUM
S_CTLG_CAT_SRC
SRC_SUB_TYPE
[SRC_ID].[SUB_TYPE]
S_SRC
SUB_TYPE
S_CTLGCAT_ASSET
ASSET_ASSET_NUM
S_ASSET
ASSET_NUM
S_CTLGCAT_ASSET
ASSET_SERIAL_NUM
[ASSET_ID].[SERIAL_NUM]
S_ASSET
SERIAL_NUM
S_CTLGCAT_PATH
CS_PATH_NAME
[CS_PATH_ID].[NAME]
S_CS_PATH
NAME
S_CTLGCT_RESITM
RI_INTR_PUBL_FLG
[RES_ITEM_ID].[INTR_PUBLISH_FLG]
S_RES_ITEM
INTR_PUBLISH_FLG
S_CTLGCT_RESITM
RI_NAME
[RES_ITEM_ID].[NAME]
S_RES_ITEM
NAME
S_CTLGCT_RESITM
RI_TYPE_CD
[RES_ITEM_ID].[TYPE_CD]
S_RES_ITEM
TYPE_CD
S_DOC_AGREE_BU
AGREE_NAME
[AGREEMENT_ID].[NAME]
S_DOC_AGREE
NAME
S_DOC_AGREE_BU
AGREE_STAT_CD
[AGREEMENT_ID].[STAT_CD]
S_DOC_AGREE
STAT_CD
S_DOC_AGREE_BU
AGREE_VALID_FLG
[AGREEMENT_ID].[VALID_FLG]
S_DOC_AGREE
VALID_FLG
S_DOC_PPSL_BU
PPSL_DFLT_TMPL_FLG
[DOC_PPSL_ID].[DFLT_TEMPLATE_FLG]
S_DOC_PPSL
DFLT_TEMPLATE_FLG
S_DOC_PPSL_BU
PPSL_NAME
[DOC_PPSL_ID].[NAME]
S_DOC_PPSL
NAME
S_DOC_PPSL_BU
PPSL_TEMPLATE_FLG
[DOC_PPSL_ID].[TEMPLATE_FLG]
S_DOC_PPSL
TEMPLATE_FLG
S_DOC_PPSL_BU
PPSL_TYPE_CD
[DOC_PPSL_ID].[PPSL_TYPE_CD]
S_DOC_PPSL
PPSL_TYPE_CD
S_DOC_QUOTE_BU
DOC_QTE_NUM
[DOC_QUOTE_ID].[QUOTE_NUM]
S_DOC_QUOTE
QUOTE_NUM
S_DOC_QUOTE_BU
DOC_QTE_REV_NUM
[DOC_QUOTE_ID].[REV_NUM]
S_DOC_QUOTE
REV_NUM
S_DOC_QUOTE_BU
DOC_QUOTE_NAME
[DOC_QUOTE_ID].[NAME]
S_DOC_QUOTE
NAME
S_INSCLM_BU
INSCLAIM_NUM
[INSCLM_ID].[INSCLAIM_NUM]
S_INS_CLAIM
INSCLAIM_NUM
S_INSCLM_BU
REV_NUM
[INSCLM_ID].[REVISION_NUM]
S_INS_CLAIM
REVISION_NUM
S_INSCLMEL_BU
SEQ_NUM
[INSCLM_ELMNT_ID].[SEQ_NUM]
S_INSCLM_ELMNT
SEQ_NUM
S_INSCLMEL_BU
TYPE_CD
[INSCLM_ELMNT_ID].[TYPE_CD]
S_INSCLM_ELMNT
TYPE_CD
S_INV_TXN_BU
INV_TXN_NUM
[INV_TXN_ID].[INV_TXN_NUM]
S_INV_TXN
INV_TXN_NUM
S_ISS_BU
ISS_LANG_ID
[ISS_ID].[LANG_ID]
S_ISS
LANG_ID
S_ISS_BU
ISS_NAME
[ISS_ID].[NAME]
S_ISS
NAME
S_LOY_MEM_BU
MEM_NUM
[MEMBER_ID].[MEM_NUM]
S_LOY_MEMBER
MEM_NUM
S_LOY_MEM_BU
MEM_TYPE_CD
[MEMBER_ID].[MEM_TYPE_CD]
S_LOY_MEMBER
MEM_TYPE_CD
S_LOY_MEM_PSTN
MEM_NUM
S_LOY_MEMBER
MEM_NUM
S_LOY_MEM_PSTN
MEM_TYPE_CD
S_LOY_MEMBER
MEM_TYPE_CD
S_LOY_PROG_BU
PROG_NAME
[PROG_ID].[NAME]
S_LOY_PROGRAM
NAME
S_LOY_PROMO_BU
PROMO_NAME
[PROMO_ID].[NAME]
S_LOY_PROMO
NAME
S_LOY_PROMO_BU
PROMO_NUM
[PROMO_ID].[PROMO_NUM]
S_LOY_PROMO
PROMO_NUM
S_LOY_TXN_BU
TXN_NUM
[TXN_ID].[TXN_NUM]
S_LOY_TXN
TXN_NUM
S_LOY_TXN_BU
TXN_STATUS_CD
[TXN_ID].[STATUS_CD]
S_LOY_TXN
STATUS_CD
S_LOY_TXN_BU
TXN_SUB_TYPE_CD
[TXN_ID].[SUB_TYPE_CD]
S_LOY_TXN
SUB_TYPE_CD
S_LOY_TXN_BU
TXN_TYPE_CD
[TXN_ID].[TYPE_CD]
S_LOY_TXN
TYPE_CD
S_MDF_BU
MDF_UID
[MDF_ID].[MDF_UID]
S_MDF
MDF_UID
S_OPTY_BU
OPTY_NAME
[OPTY_ID].[NAME]
S_OPTY
NAME
S_OPTY_BU
SUM_CLASS_CD
[OPTY_ID].[SUM_CLASS_CD]
S_OPTY
SUM_CLASS_CD
S_OPTY_BU
SUM_COMMIT_FLG
[OPTY_ID].[SUM_COMMIT_FLG]
S_OPTY
SUM_COMMIT_FLG
S_OPTY_BU
SUM_COST_AMT
[OPTY_ID].[SUM_COST_AMT]
S_OPTY
SUM_COST_AMT
S_OPTY_BU
SUM_DOWNSIDE_AMT
[OPTY_ID].[SUM_DOWNSIDE_AMT]
S_OPTY
SUM_DOWNSIDE_AMT
S_OPTY_BU
SUM_EFFECTIVE_DT
[OPTY_ID].[SUM_EFFECTIVE_DT]
S_OPTY
SUM_EFFECTIVE_DT
S_OPTY_BU
SUM_MARGIN_AMT
[OPTY_ID].[SUM_MARGIN_AMT]
S_OPTY
SUM_MARGIN_AMT
S_OPTY_BU
SUM_REVN_AMT
[OPTY_ID].[SUM_REVN_AMT]
S_OPTY
SUM_REVN_AMT
S_OPTY_BU
SUM_TYPE_CD
[OPTY_ID].[SUM_TYPE_CD]
S_OPTY
SUM_TYPE_CD
S_OPTY_BU
SUM_UPSIDE_AMT
[OPTY_ID].[SUM_UPSIDE_AMT]
S_OPTY
SUM_UPSIDE_AMT
S_OPTY_BU
SUM_WIN_PROB
[OPTY_ID].[SUM_WIN_PROB]
S_OPTY
SUM_WIN_PROB
S_OPTY_POSTN
NEW_LOAN_FLG
[OPTY_ID].[NEW_LOAN_FLG]
S_OPTY
NEW_LOAN_FLG
S_OPTY_POSTN
OPTY_CLOSED_FLG
[OPTY_ID].[CLOSED_FLG]
S_OPTY
CLOSED_FLG
S_OPTY_POSTN
OPTY_NAME
[OPTY_ID].[NAME]
S_OPTY
NAME
S_OPTY_POSTN
SUM_CLASS_CD
S_OPTY
SUM_CLASS_CD
S_OPTY_POSTN
SUM_COMMIT_FLG
S_OPTY
SUM_COMMIT_FLG
S_OPTY_POSTN
SUM_COST_AMT
S_OPTY
SUM_COST_AMT
S_OPTY_POSTN
SUM_DOWNSIDE_AMT
S_OPTY
SUM_DOWNSIDE_AMT
S_OPTY_POSTN
SUM_EFFECTIVE_DT
S_OPTY
SUM_EFFECTIVE_DT
S_OPTY_POSTN
SUM_MARGIN_AMT
S_OPTY
SUM_MARGIN_AMT
S_OPTY_POSTN
SUM_REVN_AMT
S_OPTY
SUM_REVN_AMT
S_OPTY_POSTN
SUM_TYPE_CD
S_OPTY
SUM_TYPE_CD
S_OPTY_POSTN
SUM_UPSIDE_AMT
S_OPTY
SUM_UPSIDE_AMT
S_OPTY_POSTN
SUM_WIN_PROB
S_OPTY
SUM_WIN_PROB
S_ORDER_BU
ORDER_CAT_CD
[ORDER_ID].[ORDER_CAT_CD]
S_ORDER
ORDER_CAT_CD
S_ORDER_BU
ORDER_DT
[ORDER_ID].[ORDER_DT]
S_ORDER
ORDER_DT
S_ORDER_BU
ORDER_NUM
[ORDER_ID].[ORDER_NUM]
S_ORDER
ORDER_NUM
S_ORDER_POSTN
ORDER_CAT_CD
S_ORDER
ORDER_CAT_CD
S_ORDER_POSTN
ORDER_DT
S_ORDER
ORDER_DT
S_ORDER_POSTN
ORDER_NUM
S_ORDER
ORDER_NUM
S_ORG_BU
ORG_CMPT_FLG
[ORG_ID].[CMPT_FLG]
S_ORG_EXT
CMPT_FLG
S_ORG_BU
ORG_FACILITY_FLG
[ORG_ID].[FACILITY_FLG]
S_ORG_EXT
FACILITY_FLG
S_ORG_BU
ORG_INVSTR_FLG
[ORG_ID].[INVSTR_FLG]
S_ORG_EXT
INVSTR_FLG
S_ORG_BU
ORG_LOC
[ORG_ID].[LOC]
S_ORG_EXT
LOC
S_ORG_BU
ORG_NAME
[ORG_ID].[NAME]
S_ORG_EXT
NAME
S_ORG_BU
ORG_PRTNR_FLG
S_ORG_EXT
PRTNR_FLG
S_ORG_BU
ORG_REF_CUST_FLG
[ORG_ID].[REFERENCE_CUST_FLG]
S_ORG_EXT
REFERENCE_CUST_FLG
S_ORG_BU
ORG_SRV_PROVDR_FLG
[ORG_ID].[SRV_PROVDR_FLG]
S_ORG_EXT
SRV_PROVDR_FLG
S_ORG_DIST_LST
OU_ID
[ORG_PROD_ID].[OU_ID]
S_ORG_PROD
OU_ID
S_ORG_GROUP_BU
OG_GROUP_NAME
[ORG_GROUP_ID].[GROUP_NAME]
S_ORG_GROUP
GROUP_NAME
S_ORG_GROUP_BU
OG_GROUP_TYPE_CD
[ORG_GROUP_ID].[GROUP_TYPE_CD]
S_ORG_GROUP
GROUP_TYPE_CD
S_ORG_GROUP_BU
OG_NAME
[ORG_GROUP_ID].[NAME]
S_ORG_GROUP
NAME
S_ORGGRP_POSTN
GROUP_TYPE_CD
[ORGGRP_ID].[GROUP_TYPE_CD]
S_ORG_GROUP
GROUP_TYPE_CD
S_ORGGRP_POSTN
GRP_GROUP_NAME
[ORGGRP_ID].[GROUP_NAME]
S_ORG_GROUP
GROUP_NAME
S_PARTY_GRP_BU
PG_NAME
[PARTY_GROUP_ID].[NAME]
S_PARTY_GROUP
NAME
S_PERIOD_BU
PERIOD_NAME
[PERIOD_ID].[NAME]
S_PERIOD
NAME
S_POS_BU
POS_NUM
[POS_ID].[POS_NUM]
S_POS
POS_NUM
S_POSTN_CON
AGENT_FLG
[CON_ID].[AGENT_FLG]
S_CONTACT
AGENT_FLG
S_POSTN_CON
MEMBER_FLG
[CON_ID].[MEMBER_FLG]
S_CONTACT
MEMBER_FLG
S_PRIFCTR_ITM
PRIMDL_ID
[PRIMDL_FCTR_ID].[PRIMDL_ID]
S_PRIMDL_FCTR
PRIMDL_ID
S_PROD_DFCT_BU
DEFECT_NUM
S_PROD_DEFECT
DEFECT_NUM
S_PROD_INT_BU
PROD_EFF_END_DT
[PROD_INT_ID].[EFF_END_DT]
S_PROD_INT
EFF_END_DT
S_PROD_INT_BU
PROD_EFF_START_DT
[PROD_INT_ID].[EFF_START_DT]
S_PROD_INT
EFF_START_DT
S_PROD_STYL_TNT
SETUP_STYLE_CD
[PROP_STYLE_ID].[SETUP_STYLE_CD]
S_PROD_STYL_TNT
SETUP_STYLE_CD
S_PROJ_BU
PROJ_NAME
[PROJ_ID].[NAME]
S_PROJ
NAME
S_PROJ_BU
PROJ_STATUS_CD
[PROJ_ID].[STATUS_CD]
S_PROJ
STATUS_CD
S_PROJ_BU
PROJ_TYPE_CD
[PROJ_ID].[PROJ_TYPE_CD]
S_PROJ
PROJ_TYPE_CD
S_PSP_PROC_BU
VOD_NAME
[VOD_ID].[VOD_NAME]
S_VOD
VOD_NAME
S_QUOTE_POSTN
QUOTE_NUM
[QUOTE_ID].[QUOTE_NUM]
S_DOC_QUOTE
QUOTE_NUM
S_SALES_MTHD_BU
SALES_METHOD_NAME
[SALES_METHOD_ID].[NAME]
S_SALES_METHOD
NAME
S_SRC_BU
SRC_NAME
[SRC_ID].[NAME]
S_SRC
NAME
S_SRV_REQ_BU
SR_AREA
[SRV_REQ_ID].[SR_AREA]
S_SRV_REQ
SR_AREA
S_SRV_REQ_BU
SR_CST_NUM
[SRV_REQ_ID].[SR_CST_NUM]
S_SRV_REQ
SR_CST_NUM
S_SRV_REQ_BU
SR_NUM
S_SRV_REQ
SR_NUM
S_SRV_REQ_BU
SR_SEV_CD
[SRV_REQ_ID].[SR_SEV_CD]
S_SRV_REQ
SR_SEV_CD
S_SRV_REQ_BU
SR_STAT_ID
[SRV_REQ_ID].[SR_STAT_ID]
S_SRV_REQ
SR_STAT_ID
S_SRV_REQ_BU
SR_SUB_STAT_ID
[SRV_REQ_ID].[SR_SUB_STAT_ID]
S_SRV_REQ
SR_SUB_STAT_ID
S_SRV_REQ_BU
SR_TITLE
[SRV_REQ_ID].[SR_TITLE]
S_SRV_REQ
SR_TITLE
S_SRV_REQ_BU
SR_TYPE_CD
[SRV_REQ_ID].[SR_TYPE_CD]
S_SRV_REQ
SR_TYPE_CD
S_TMPL_PLNIT_BU
PLANITEM_NAME
[TMPL_PLANITEM_ID].[NAME]
S_TMPL_PLANITEM
NAME
S_TMPL_PLNIT_BU
PLANITEM_TYPE_CD
[TMPL_PLANITEM_ID].[TYPE_CD]
S_TMPL_PLANITEM
TYPE_CD
S_TMPL_PLNIT_BU
PLNIT_TMPL_TYPE_CD
[TMPL_PLANITEM_ID].[TMPL_TYPE_CD]
S_TMPL_PLANITEM
TMPL_TYPE_CD
S_USERLIST_BU
UL_NAME
[USERLIST_ID].[NAME]
S_USERLIST
NAME
S_WRNTY_CVRG_BU
WRNTY_CVRG_NAME
[WRNTY_CVRG_ID].[WRNTY_NAME]
S_WRNTY_CVRG
WRNTY_NAME
T_MASTER_BU
MASTER_ALIAS
[MASTER_ID].[ALIAS]
T_MASTER
ALIAS
T_MASTER_BU
MASTER_NAME
[MASTER_ID].[NAME]
T_MASTER
NAME
T_MASTER_DETAIL
DETAIL_SX2_NAME
[DETAIL_SX2_ID].[SX2_NAME]
T_DETAIL_SX2
SX2_NAME
T_MASTER_DETAIL
MASTER_NAME
[MASTER_ID].[NAME]
T_MASTER
NAME
T_MASTER_PER
MASTER_ALIAS
[MASTER_ID].[ALIAS]
T_MASTER
ALIAS
T_MASTER_POSTN
MASTER_NAME
[MASTER_ID].[NAME]
T_MASTER
NAME
