Upgrade Guide for DB2 UDB for z/OS > Reviewing the Database Upgrade Log Files >
Reviewing Upgrade Log Files for Errors
Upgrades: All upgrades. Environments: All environments. This topic is part of an upgrade process. See How to Perform the Upgrade. You should review the logs created when you run the Siebel Upgrade Wizard to verify that the upgrade process completed correctly and to identify errors that must be resolved. The log files may include errors that are expected and benign. You must compare any error messages found in the log files to a list of acceptable error messages, and correct any non-benign errors. Complete the following procedure to manually review log files for unacceptable errors.
