/u |
Username. For example, sbladm . This argument is required. |
/p |
Password. This argument is required. |
/c |
ODBC Data Source. This argument is required. |
/d |
Siebel Table Owner. This argument is required. |
/e |
Specify Y to execute RUNSTATS on entire schema. Default = N . |
/t |
Specify the table for which you want to execute RUNSTATS. |
/a |
Specify Y to RUNSTATS on all tables in table space. Default = N . |
/i |
Specify Y to ignore errors. This applies to the entire schema only. Default = N. |
/l |
Specify directory and filename for log file. Default filename = rstat390.log. |
/s |
Sample value. Default = 25. |
