Upgrade Guide for DB2 UDB for z/OS > Upgrading a Development Environment Database from the Midtier >
Executing SQL Output Files After the Third Pause
Upgrades: All upgrades. Environments: Development (midtier-centric) environment. This topic is part of an upgrade process. See How to Perform the Upgrade. The output files created by the Siebel Upgrade Wizard before the third pause message are generated into the default output directory or into the output directory that you specified in Table 22. Windows: The default DDL output directory is DBSRVR_ROOT \db2390 \dboutput \upgrade. UNIX: The default DDL output directory is DBSRVR_ROOT /db2390 /dboutput /upgrade. To execute the SQL output files after the third pause
After successfully executing the SQL files and reviewing the log files for unacceptable errors, continue with the upgrade from the point at which it paused.
