Upgrade Guide for DB2 UDB for z/OS > Upgrading a Database from the Mainframe > Executing the Upgrade on the z/OS Host (Phase 1 of 2) >
Migrating Preschm Data for FINS
Complete the following procedure to migrate preschm data for Siebel Financial Services (FINS) applications. Prerequisite task: Migrating Preschm Data. NOTE: This topic applies to upgrades from Siebel Financial Services 6.2.1, 7.0.4, 7.5.2, and 7.7 applications.
To migrate preschm data for FINS applications
- If you are not on the Siebel Upgrade Main Menu, enter the following command:
TSO SBLUPG78
- Select option 5: RUN UPGRADE / POST-UPGRADE MAINTENANCE.
The panel ID is SBLRUNFP.
- Select option 8: PRESCHM-FINS.
This places you in edit mode for dataset DSNHLQ .SIEBEL.INSTALL.JCL(SUBPSF) .
- Run the job using the JCL in dataset
DSNHLQ .SIEBEL.INSTALL.JCL(SUBPSF) . This job automatically submits the first PRESCHM job referenced in dataset DSNHLQ .SIEBEL.EXEC(@PRESCHF).
- If this job runs successfully, it automatically submits the next dependent job, and so on.
- This process continues for all PRESCHM-FINS jobs. If a job fails, the succeeding dependent job does not get submitted. The automatic job submission sequence terminates.
- After all PRESCHM FINS jobs have run, verify that each job ran successfully.
RC=0 , RC=4 , or RC=8 indicates that the job was successful. RC=8 is associated with jobs that have an X in position 3 of the member name.
Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
If you selected Siebel-Scheduled Mode, this job is logged (as Completed Successfully or Failed) to the target Siebel log table: TARGET_TABLEOWNER .TMP_SBLLOG_TAR .
NOTE: You must fix any failed jobs before proceeding with the upgrade. For information on restarting failed jobs, see Restarting Failed Jobs on the Mainframe.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- View the job status.
For information on how to view job status if you selected Siebel-Scheduled Mode, see Viewing the Siebel Job Log Status.
