Upgrade Guide for DB2 UDB for z/OS > Upgrading a Database from the Mainframe > Executing the Upgrade on the z/OS Host (Phase 2 of 2) >
Dropping Old Indexes and Creating New Indexes
Perform the following procedures to drop old schema indexes and create new schema indexes. To drop old index schemas
- Make sure you are at the Siebel Upgrade Job Submission Menu for your upgrade.
- For Siebel Business application upgrades, the panel ID is SBLRUNHP.
- For Siebel Industry application (SIA) upgrades, the panel ID is SBLRUNFP.
- Select the option for the application you are upgrading.
- Run the job using the JCL in dataset
DSNHLQ .SIEBEL.INSTALL.JCL(@GPDRPIX) . This job runs DDL to drop old-schema non-unique indexes.
NOTE: After running this job, verify that it was successful by reviewing the sysout in SDSF or another job output facility and making sure the RC=0.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- Verify that the JCLTEST return code is
FLUSH (RC=0 or RC=4 ). If you do not see the FLUSH return code, you can verify the condition codes by searching for the condition code IEF206I.
Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
If you selected Siebel-Scheduled Mode, this job is logged (as Completed Successfully or Failed) to the target Siebel log table: TARGET_TABLEOWNER .TMP_SBLLOG_TAR .
NOTE: You must fix any failed jobs before proceeding with the upgrade. For information on restarting failed jobs, see Restarting Failed Jobs on the Mainframe.
After the ###DRPIX job has successfully completed, run the PRE-GEN PRIMARY INDEX DDL job to create new index schemas. To create new index schemas
- Make sure you are at the Siebel Upgrade Job Submission Menu.
DSNHLQ .SIEBEL.INSTALL.JCL(@GPPREIX). This job runs DDL to create new-schema, non-unique indexes.
Verify that the JCLTEST return code is FLUSH (RC=0 or RC=4 ). If you do not see the FLUSH return code, you can verify the condition codes by searching for the condition code IEF206I. Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
