Upgrade Guide for DB2 UDB for z/OS > Upgrading a Database from the Mainframe >
Performing Intersection Table Maintenance
Upgrades: All upgrades. Environments: Production test, production. This topic is part of an upgrade process. See How to Perform the Upgrade. The intersection table maintenance jobs (ITM) identify and resolve potential duplicate row IDs from intersection tables. To run the intersection table maintenance process
- Make sure you are at the Siebel Upgrade Job Submission Menu for your upgrade path.
The Panel ID is SBLRUNFP.
- Select the appropriate menu option for your upgrade path for intersection table maintenance:
- For Siebel Business application upgrades, select option 16: INTERSECTION TABLE MAINT.
- For Siebel Industry application upgrades, selection option 19: INTERSECTION TABLE MAINT.
- On the ITM Maintenance Process Menu (Panel ID SBLITMP), select option 0: CHANGE JCL TEMPLATES - SET DSNHLQ (REQUIRED), and then press Enter.
- On the ITM Maintenance Process Menu (Panel ID SBLITMP), select option 1: BUILD/POPULATE PDS DATASETS (UNPACK03), and then press Enter.
This places you in edit mode for dataset DSNHLQ .SIEBEL.INSTALL.JCL(UNPACK03) .
- Run the job using the JCL in dataset
This job populates (unpacks) all ITM JCL and SQL PDS members into their corresponding PDS datasets.
DSNHLQ .SIEBEL.ITM.SQL
DSNHLQ .SIEBEL.ITM.JCL
- Verify that the job ran successfully.
RC=0 indicates that the job was successful.
Verify that the JCLTEST return code is FLUSH. If you do not see the FLUSH return code, you can verify the condition codes by searching for the condition code IEF206I.
Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
If you selected Siebel-Scheduled Mode, this job is logged (as Completed Successfully or Failed) to the target Siebel log table: TARGET_TABLEOWNER .TMP_SBLLOG_TAR .
NOTE: You must fix any failed jobs before proceeding with the upgrade. For information on restarting failed jobs, see Restarting Failed Jobs on the Mainframe.
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- On the ITM Maintenance Process Menu (the panel ID is SBLITMP), select option 2: ADD JOBCARDS TO INTERSECTION TABLE MAINTENANCE (ITM) JOBS, and then press Enter.
- At the prompt, enter a three-character job name prefix, and then press Enter.
NOTE: The job name prefix is used for the ITM JCL generated for the Update and Delete jobs.
A message indicates that the JCL generation is in process, then a series of messages indicates the number of jobs generated. The number of jobs varies by upgrade path.
- When three asterisks (***) appear at the bottom of the display messages, press Enter to return to the ITM Maintenance Process Menu.
The jobcards are added to the JCL templates.
- On the ITM Maintenance Process Menu (the panel ID is SBLITMP), select option 4: RUN UNLOAD JOBS, and then press Enter.
This places you in edit mode for dataset DSNHLQ .SIEBEL.INSTALL.JCL(SUBITMUL) .
TIP: If you want to run the ITM Unload jobs manually, select option 3 to view the PDS list of all unload jobs. Option 4 submits all ITM Unload jobs in a single job submission.
- To run the job using the JCL in dataset
DSNHLQ .SIEBEL.INSTALL.JCL(SUBITMUL) , enter submit on the command line and then press Enter.
This job automatically submits all the unload jobs references in datasets DSNHLQ .SIEBEL.EXEC(@ITMUL) .
- Verify that this job (and all jobs submitted automatically) ran successfully.
RC=0 or RC=4 indicates that the job was successful. Jobs with an ABEND (end abnormally) U99 or U099 message are jobs that failed.
TIP: To review a list of all jobs submitted automatically, view datasets DSNHLQ .SIEBEL.EXEC(@ITMUL) . This corresponds to all PDS members listed in option 3.
- On the ITM Maintenance Process Menu (the panel ID is SBLITMP), select option 5: RUN DELETE/UPDATE JOBS USING PDS LIST, and then press Enter.
This places you in edit mode for dataset DSNHLQ .SIEBEL.ITMJOBS.JCL . This is a PDS, so all PDS members are listed.
NOTE: If a message indicates that no maintenance jobs were generated, either option 4 was not run or no tables require maintenance.
- To run each PDS member job using the JCL in dataset
DSNHLQ .SIEBEL.ITMJOBS.JCL , select a PDS member, enter submit on the command line and press Enter. Repeat for each PDS member.
All jobs can run in parallel (that is, at the same time).
