Upgrade Guide for DB2 UDB for z/OS > Performing the Siebel Tools Repository Merge >
Reviewing Deleted Objects in the Repository Merge
Upgrades: All upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. Deleted objects are those that were in the repository when it was installed but that you have since deleted. The merge retrieves these objects from the Prior Siebel Repository and adds them to the New Customer Repository. Typically, adding these objects does not cause a problem with your upgraded configuration. Prerequisite: The repository merge must have been successful. See Determining If a Repository Merge Was Successful. To generate a list of deleted objects
- In Siebel Tools, navigate to Screens > Application Upgrader > Application Upgrade Object List.
- In the Application Upgrades list, select the record of the successful merge.
- Click Query.
- Enter your query criteria in the Object Differences list:
- Click in the In Prior Standard field so that a check mark appears.
- Click in the Added to New Customized field so that a check mark appears.
- Click in the In Prior Customized field so that a check mark appears. Then click in it again so that no check mark appears.
- Press Enter to run the query.
Deleted objects appear in the Object Differences list. You can filter the objects displayed by using the Top Parent Type and Object Type fields.
- Review the list carefully to determine that deleted objects that have been restored to the merged repository will not have an adverse effect on upgraded applications.
