Upgrade Guide for DB2 UDB for z/OS > Application Upgrade Planning >
Upgrade Planning for Resonate Central Dispatch
Upgrades: Releases 7.0.x, 7.5.x. Support for Resonate Central Dispatch is discontinued as of Release 7.7. It has been replaced by a load balancing module that is included in the Siebel Web Server Extension. In addition, Siebel Systems has certified several third-party HTTP load balancers for use with the Siebel Web Server Extension. For a description of the Siebel load balancing module, see Siebel System Administration Guide and Siebel Installation Guide for the operating system you are using. For a list of supported HTTP load balancers, see Siebel System Requirements and Supported Platforms on Oracle Technology Network.
