Upgrade Guide for DB2 UDB for z/OS > Database and UI Upgrade Planning > Planning Your Upgrade >
Obtaining Required Software and Hardware
Because each enterprise has specific needs for hardware and software resources, it is recommended that you discuss your particular situation with your Siebel technical resource. Make sure your hardware supports the needs of your Siebel 7.8 upgrade. CAUTION: Read Siebel System Requirements and Supported Platforms on Oracle Technology Network to verify the supported computer and operating system platforms and supported third-party programs for this release of your Siebel Business applications.
