Upgrade Guide for DB2 UDB for z/OS > Database and UI Upgrade Planning >
About Multilingual Deployments
Upgrades: All upgrades. Environments: All environments. The upgrep process imports repository strings and seed data in only the primary language. The primary language, also called the base language, is the language in which data is stored in the Siebel Database. If you have multilingual deployments, therefore, you must import multilingual repository strings and seed data after performing the upgrep upgrade process. For instructions on how to perform these imports, see 477094.1 (Article ID) on My Oracle Support. This document was formerly published as Siebel Technical Note 447. See the Siebel Installation Guide for the operating system you are using for instructions on installing and configuring multiple Siebel language packs. For a list of supported code pages and encoding strategies, see Siebel System Requirements and Supported Platforms on Oracle Technology Network.
