Upgrade Guide for DB2 UDB for z/OS > Database and UI Upgrade Planning >
About User Interface Changes
Upgrades: Releases 7.0.x, 7.5.x. Environments: All environments. Several important changes to the user interface were introduced in Siebel 7.7:
- Revised navigation scheme. The key revisions were as follows:
- The Show menu is replaced by a link bar. When you click on a screen tab, the link bar displays below the screen tab and shows the views or view list for the screen.
- A visibility filter menu, located in the parent list applet, provides alternative methods for filtering the data displayed in the applet.
- To display view tabs, users click on a link in the parent list applet.
- Revised UI configuration. In prior releases, placement of views and controls were based on repository configuration and logic applied at run time. Since Release 7.7, placement of views and controls is declarative in the repository. No run-time logic is applied.
- Expanded use of grid-layout applets. To improve usability, most employee-specific form applets are converted to grid-based layout.
- MVG shuttle applets. MVG shuttle applets were introduced in Release 7.5.x. In Release 7.7, MVGs are shuttle-enabled by default.
Because of these enhancements, you should plan a careful evaluation of the user interface after upgrade. The upgrade logging utility will list any user interface-related problems encountered during upgrade. For more information on the user interface, see Fundamentals.
