Upgrade Guide for DB2 UDB for z/OS > Database and UI Upgrade Planning >
About the New Column Added to S_SRC_PAYMENT
Upgrades: Release 6.2.1 only. Environments: All environments. The S_SRC_PAYMENT table has a new required column, TYPE_CD. The default value for this column is Payment. This value indicates that this is a payment from your organization to an external organization. For example, this might denote a payment of marketing funds to your customer. If your organization has used the S_SRC_PAYMENT table to store other types of payments (particularly, payments from your customers to your organization), you must reset the parameter in this column to fit your data and run Siebel Systems' Enterprise Integration Management (EIM) product. This updates the table and enables you to review your results before migrating to your production environment. The valid values for this column as shipped with Siebel Business applications are:
- Payment
- Receipt
- Write-Off
- Adjustment
For information on how to update the Lists of Values, see Configuring Siebel Business Applications.
