Upgrade Guide for DB2 UDB for z/OS > Database and UI Upgrade Planning > Planning Your Upgrade >
Testing Before a Production Upgrade
Careful testing is critical for a successful upgrade. In particular, the production upgrade must be thoroughly tested to avoid data-specific issues and gain the best possible performance during your upgrade. NOTE: Do not go live on Siebel 7.8 without exhaustive performance testing.
