Upgrade Guide for DB2 UDB for z/OS > Migrating Siebel 6.2.1 Customizations >
Running the Web Layout Wizard
Upgrades: Release 6.2.1 only. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform the Upgrade. If some views or applets did not migrate properly when you ran the Siebel Web Client Migration Wizard to upgrade to Release 7.8, you can remigrate them using the Web Layout Wizard. With the Web Layout Wizard you can migrate applets or views individually or in groups. When you select applets for migration, they must be in the same base class. When you select views, they must be of the same type. You can run the Web Layout Wizard on applets and views multiple times. For more information on migrating created or modified applets and views to the Siebel Web Client, see About Migrating to the Siebel Web Client. To run the Web Layout Wizard
- For applets, identify the desired model applet you want to use. For views, identify the desired model view.
You may need to modify a model applet or model view to obtain the desired characteristics.
- In Siebel Tools list view, select the applets or views you want to migrate.
- In the list view, right-click and select Web Layout Wizard.
- In the Web Client Migration dialog box, verify that all the applets or views you want to migrate are selected. Click Next.
- Select the model applet or model view you identified.
- Click Next to migrate the applets or views.
- Review the conversion results. Repeat the procedure if needed.
