Upgrade Guide for DB2 UDB for z/OS > Basic Database Preparations >
Creating Storage Groups
Upgrades: All upgrades. Environments: Development environment only. Before upgrading the Siebel Database Server, your DBA must create storage groups on the target database. The upgrade process assumes that the names for the storage groups in the target database are the same as those defined in the source database. For this reason, the names used to define the storage groups for the target database should be the same as those defined on the source database. If the names are not the same, your DBA must manually modify the schema.sql file so that the names match.
