Using Siebel Tools > About the Siebel Tools User Interface >
About the Properties Window
The Properties window (shown in Figure 8) displays the property settings for the object currently highlighted in the Object List Editor. The name of the active object is shown at the top of the window (in Figure 8, Business Component Abs Result). For each property of the object, the Properties window shows the name of the property in the left column, and the property's value in the right column. By default, the Properties window appears with the Alphabetic tab active; you can click the Categorized tab to see the properties grouped by category.
NOTE:  The Properties window does not display the Project and Changed properties.
Figure 8. Example of the Properties Window
Using Siebel Tools
