Using Siebel Tools > Customizing Your Siebel Tools Environment >
Restarting Editors After Check Out
You can set an option that automatically restarts any open editors after the check out process finishes.
To restart editors after check out
  1. Choose View > Options.
    The Development Tools Options dialog box appears.
  2. Click the Check In/Out tab.
  3. Select the Restart the editors after Check Out check box.
    Any editors that are open at the time you begin the Check Out process are restarted when the Check Out process finishes.
  4. Click OK.
Using Siebel Tools
