Using Siebel Tools > Customizing Your Siebel Tools Environment >
Defining the Web Template Editor
The Web template editor is an external application that you define here and that you can open using a right-click menu in the Web template explorer. For example, in the Web template explorer, navigate to a given Web template, then right-click, and the application defined as the default editor opens with the selected Web template automatically displayed.
To define the default path for Web template files
  1. Choose View > Options.
    The Development Tools Options dialog box appears.
  2. Click the Web Template Editor tab.
  3. In the Folder full path field, type the full path to location of your Web template files.
  4. Under External Web template editor, do the following:
    1. Use the Browse button in the Executable full path field to navigate to and select the executable for the external Web editor.
    2. In the Optional parameters field, enter the parameters you want to pass to the executable when you launch the external editor.
  5. Click OK.
Using Siebel Tools
