Using Siebel Tools > Customizing Your Siebel Tools Environment >
Customizing Visualization Views
You can customize the font and appearance of visualization views. To customize visualization views
- Choose View > Options.
The Development Tools Options dialog box appears.
- Click the Visualization tab.
- Use the information in the following table to define your options under Font.
Use system font |
Select this option to let Siebel Tools use a system font for the visualization views. |
Use a Custom Font |
Select this option to choose your preferred font for the visualization views. When you select this option, you must use the Font, Size, and Zoom drop-down lists to define your preferences. |
- Use the information in the following table to define your options under Object style, and then click OK.
Boxes with 3D borders |
Displays boxes with a 3D border. |
Icon and name only |
Displays object name and object icon (the same icon used in the Object Explorer). |
Simple outline boxes |
Displays object names in simple boxes. |
Always print outline style |
Prints visualization details in outline style. |
