Using Siebel Tools > Customizing Your Siebel Tools Environment >
Showing and Hiding Windows
You show and hide windows using toggles on the View menu. To show or hide a window using the View menu
- Choose View > Windows.
A list of windows appears in a secondary pop-up menu. A visible window is identified with a check mark. A hidden window has no marker.
- Select the window you want to show or hide.
If the window was hidden, it appears. If the window was visible, it is hidden.
NOTE: To show or hide the Bookmarks window, you can also use the Go menu (Go > Bookmarks List).
To hide a window using a right-click menu
- Right-click the window title of the window you want to hide.
- From the pop-up menu that appears, choose Hide.
The window no longer appears in the Siebel Tools application window.
Related Topics
Docking Windows
Showing and Hiding the Object Explorer
