Using Siebel Tools > Customizing Your Siebel Tools Environment >
Showing and Hiding Confirmation Dialog Boxes
You can choose to show or hide dialog boxes that pop up to confirm you want to perform a given action, such as delete.
To show or hide confirmation dialog boxes
  1. Choose View > Options.
    The Development Tools Options dialog box appears.
  2. Click the General tab.
  3. Under Editing confirmation dialogs, select the check boxes for the confirmation dialog boxes you want to see, and clear the check boxes for the confirmation dialog boxes you do not want to see.
  4. Click OK.
Using Siebel Tools
