Using Siebel Tools > Customizing Your Siebel Tools Environment >
Selecting a Language Mode
The Siebel Tools language mode allows you to work with locale-specific data for languages other than English. For example, setting your language mode to German (DEU) allows you to view and edit DEU-specific data stored in Locale-Objects, such as translated strings. Language mode determines the set of locale-specific data that:
  • You can view and edit in the Object List Editor.
  • Is used when compiling the repository (SRF) file.
  • Is transferred during check in and check out processes.
NOTE:  If additional languages (other than the language product versions shipped with Siebel applications) are added to the Siebel database, the language code must be in all capital letters for the code to appear in the Language Mode drop-down list. For more information on adding languages not shipped by Oracle, see Global Deployment Guide.
To set a language mode
  1. Choose View > Options.
    The Development Tools Options dialog box appears.
  2. Click the Language Settings tab.
  3. Under Tools Language Mode, select a value from the Language drop-down list, then click OK.
NOTE:  Before configuring another language, make sure that the language repository data has already been loaded into the repository. If not, load this data before beginning configuration on the language in question.
Related Topic
Enabling Language Overrides
Using Siebel Tools
