Using Siebel Tools > Getting Projects from the Server Repository > About the Get ProcessThe process of copying projects from the server database to your local database is known as performing a Get. The Get process differs from checking out in the following ways:
NOTE: The sample database, unlike a local database, cannot receive projects from the server database during a Get. The sample database is intended for instructional use only. Typically you perform a Get to initially populate your local database. This process is known as a Full Get. You can also get projects to override objects stored on your local database. Related Topics |
Using Siebel Tools |
